Hi all.
I've been wondering if the above is a good idea and if so, is relatively easy to complete?
Thanks in advance.
M20 rad fan conversion mech>elec?
votivequagmire
'88 325i M20, could've done with a sunroof.
Billwill
www.e30tech.com in the USA have a FAQ/DIY section and there is a good discussion there on putting in electric fans with good pictures.votivequagmire wrote:Hi all.
Thanks in advance.
It is a case of getting the right fan and thermal switch....they have some good ideas there although I like to keep my cars stock standard.
The standard viscous arrangement is far more reliable and energy efficient than any electric system, so best left alone.
votivequagmire
Ok. Understood. That's good enough for me. Thanks.
Mikey_Boy
There are arguments for both depending on a variety of factors... If you are staying with the viscous set up then make sure the viscous coupling isn't knackered! That makes all the difference...
Exactly! There's just one component that's ever likely to fail, and at intervals of fifteen - twenty years.Mikey_Boy wrote:There are arguments for both depending on a variety of factors... If you are staying with the viscous set up then make sure the viscous coupling isn't knackered! That makes all the difference...
An electric set up has a motor, relay, thermostat, fuses and a myriad of assorted joints, plugs and sockets, every one of which can hardly be considered highly reliable.
