I have just changed my wheels to BBS rs which fit a e30 no probs with the right spacers
Tried and tested these same wheels before this on my last sport
without any issues.
Car was fine ( However there was a abs issue which apparently is a relay) before I changed the wheels now it feels like the handbrake is on the handbrake lever is very tight. It only moves up very slightly.
When trying to accelerate away, lots of resistance and car struggles to move and hunches up when releasing clutch
So just changed the wheels back to what were on before with the same bolts and spacers, which drove fine on and now still have same issue.
It has upgraded brakes, WMS 298mm.
What could I have possibly done, a braking component stuck on.
Change of wheels, Feels like handbrake is stuck on. HELP!
325i sport tech 2, lach silver, 1989, BBS RS 16 split rims,
[URL=http://s878.photobucket.com/user/ETERNI ... 0.jpg.html][img]http://i878.photobucket.com/albums/ab35 ... 46cc30.jpg[/img
yes I did
I think you hit the nail in the headPrey wrote:a stab in the dark but you didn't use the long wheel bolts from the spacers with the other wheels? these could have bent/pushed something about in the handbrake mech if they went too far into the hub.
what now!
so do I need to take off the hub or disc
btw thanks dude
btw thanks dude
yeah i would mate - only a couple of bolts for the caliper and the retaining screw for the disc, you might have to fight the disc off though if the handbrake is dragging!
don't have to take the hub off i was getting the terminology totally wrong!
handbrake is tight
so I probably damaged the handbrake mechanism
hope so
that was so obvious, I didnt even think of it.
The wheels looked so sweet that I was like
and went and screwed in the wrong bolts
now am like
now am like
thanks
much appreciated Prey
it seems that the handbrake mech is a bit fragile unless the backplates are perfect anyway. i've ended up welding washers into my backplate so i can put bolts through to hold the shoes instead of of the twist pins as they kept falling to bits.
matt86
It sounds to me like the bolts are wedged on the caliper or caliper housing. How long are the bolts from memory I tried 50mm and the wheel wouldn't turn think 40mm length is the maximum you can go.
