Windscreen washers / headlight washers ??
Alpina99
Post Sat Jul 14, 2012 10:22 am
Getting my car ready for the MOT I had to "mechanically adjust" (bodge) the tubing to the windscreen washers,
Basically I had to remove from the system the two round valves under the washer jets, (not sure if they're windscreen only or connected to the headlamp wash / wipe system,)
With these "out of the circuit" everything worked fine,
Anyone know what they are please & are they still available ??
Gone, but not forgotten !!
Alburglar
Post Tue Jul 17, 2012 11:19 pm
They are Non return valves. Mine got blocked, spray with loads of wd40 and try and blow through them. If that fails they are cheap on eBay
M42 - rightness! with proper 4.27 LSD
Alpina99
Post Wed Jul 18, 2012 1:06 am
Thanks,
I'll check that out,
Post Wed Jul 18, 2012 3:07 pm
Post Wed Jul 18, 2012 8:36 pm
Or, even better, a '15' on here: http://bmwfans.info/parts/catalog/E30/T ... _cleaning/ from BMW from BMW.
Alpina99
Post Thu Jul 19, 2012 7:39 am
Thanks fellas,
One way or another I'll (hopefully) be able to put it back how it should be,
:D :D
