fog light on a h reg face lift model
Tusker77
How do u change the fog light bulb ?
adit
on the underside is a circular access hatch held on by a small phillips screw.
be careful to use the correct size screwdriver, so as not to "round off" the screw head. also, unscrew gently, as the screw head often snaps.
HTH
HTH
[quote="bss325i"]
Tusker77
Cheers adi, I'm getting her ready for ace in August
Half way down the front glass is a small grey rubber bung. Pull this out and unscrew the cross head screw behind it. Pull the side of the light that had the plug forwards, and the whole light will come out of its frame into your hand, enabling you to remove the circular hatch and change the H3 bulb inside.
