Front brake pad wear sensor - fitting
MarkS100
Post Sun Jul 01, 2012 5:05 pm
Hi all,
I'm trying to solve my brake warning light that is staying on. First investigation and I find no front brake pad wear indicator fitted. I now have one to fit, but can't figure out how it fits in/on the caliper. is there a photo or instruction on the site that could help guide me? Car is a 89 320i cabby with vented front disks.
Many thanks for any guidance.
Mark S.
SGP
Post Sun Jul 01, 2012 5:43 pm
The pad wear sensor actually fits into a slot in the pad. The idea being that it wears down with the pad until the wire inside breaks.
http://www.e30zone.net/e30zonewiki/index.php/Brakes
If it ain't broke..
Fix it till it is :)
MarkS100
Post Mon Jul 02, 2012 10:38 am
Many thanks.
Mark S.
Post Mon Jul 02, 2012 1:31 pm
When you've fitted the sensor, make sure that you route the wires correctly, so that they don't touch the inside of the rim when the wheel is refitted, otherwise the light will be back on in a couple of days.
