325-exhaust. Twin pipe or single
kipsy
Post Thu Jun 28, 2012 4:35 pm
What's your thoughts on what performs better? Was thinking of replacing my battered current system on my rally car. Not worried about looks etc.
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Jun 28, 2012 6:40 pm
Depends on the diameter of the pipe, surely. The diameter of each pipe in the twin-pipe system is 45mm, which gives an area of 3200 or thereabouts. So a 2.5" single pipe (63.5mm) would achieve the same area, which is what BTB used in their 6-2-1 manifold.
If you went into serious gas flow dynamics though, a single pipe has a smaller circumference than double (200mm to 280mm) meaning less surface resistance between the gas and the metalwork, so possibly a smoother flow. All depends on the quality of the system and the design of the mufflers etc.
kipsy
Post Thu Jun 28, 2012 10:11 pm
Thanks for that. It's cheaper and lighter for a single system. Don't know if they sound similar? My current scorpion twin pipe system had the centre box removed and did not have an x pipe put back in. Sounds a bit like a Porsche :( having an x piece put in next week but may get new system soon
