HELP! My boot wont open!!
m3ben05
Post Wed Nov 16, 2005 8:55 pm
Hi all, Iv just gone out to my car, gone to unlock the boot and.......nothing, i cant unlock it!!
Now, for most people, this would not be a major problem, but there is a kill switch on my battery that happens to be OFF as the car does not get used all the time, so i cant start the car :evil:
Does anyone have any idea how i could get around this, im sure if i could get power to the car, the central locking would open the boot.
PLEASE HELP ME!!!!!!
Simon
Post Wed Nov 16, 2005 9:41 pm
To get into the boot when it won't open, get an extension socket bar, place it on the boot lock, and give it a quick thump with a hammer or similar, it will open the boot, but dislodge a circlip which you'll have to find and put back together.
m3ben05
Post Wed Nov 16, 2005 9:54 pm
Thanks mate, il give it a go.
m3ben05
Post Wed Nov 16, 2005 10:06 pm
It didnt work, iv taken the back seat off, so i can get in through the hole in the back, so i can atleast turn the power back on and drive the car! still need to get it open though!!
Simon
Post Wed Nov 16, 2005 10:19 pm
So the power is back on, and the central locking is still not unlocking the boot?
Are you using the correct keys? Some well looked after E30's still have the valet keys, that won't open the boot and glovebox..
jonbuoy
Post Wed Nov 16, 2005 10:22 pm
Simon wrote:To get into the boot when it won't open, get an extension socket bar, place it on the boot lock, and give it a quick thump with a hammer or similar, it will open the boot, but dislodge a circlip which you'll have to find and put back together.
Did'nt think that worked on the bm's, only on the mk4 escort's?
If it doe's work, hit it harder!!
Other than that you will have to chisel the outside casing off around where the key goes in :(
The German's really did sort the locking out on these car's :?
m3ben05
Post Wed Nov 16, 2005 10:23 pm
Yea, the power is on and the central locking is not opening the boot. I still have the valet key, but i am using the right one.
Im guessing something has jammed up in the lock, when theres more light tomorrow il see if i can see anything
Simon
Post Wed Nov 16, 2005 10:24 pm
It's worked for me a couple of times, maybe M3 lock is different...I don't think so though...
Simon
Post Wed Nov 16, 2005 10:25 pm
m3ben05 wrote:Yea, the power is on and the central locking is not opening the boot. I still have the valet key, but i am using the right one.
So what happens when you turn the key in the boot lock? Is the deadlock on at all?
m3ben05
Post Wed Nov 16, 2005 10:29 pm
The key will turn and when its turned in the boot lock all the other doors will lock/unlock, its not slack or loose, which makes me think that there's nothing broken.
Whats the dead lock and how does it work? (sorry, i know this is going to be a stupid question!)
Thanks for the help btw
Simon
Post Wed Nov 16, 2005 10:35 pm
m3ben05 wrote:The key will turn and when its turned in the boot lock all the other doors will lock/unlock, its not slack or loose, which makes me think that there's nothing broken.
Deadlock is when you turn the key in the drivers lock anti-clockwise, it prevents all doors being opened wether by key or by pulling the locking pins.
Seeing as the car is locking/un-locking with the key at the boot then it's not a deadlock problem, and not a lock problem at the boot.
Seems just a simple jam, has it been left shut for a while?
m3ben05
Post Wed Nov 16, 2005 10:37 pm
Yea, thats what i thought. No, its been shut since monday night, and its been in a heated garage.
I dont understand but il have a look tomorrow before i go to work when there is some better light.
Thanks for all your help though mate
jonbuoy
Post Wed Nov 16, 2005 10:39 pm
Dead Lock: Lock's all door's and you cannot open them, try locking your driver's door with the window down but turn the key so it is parralel(sp) and pull the door pin up....................you can't hence dead lock.
Not exactly sure what is going on with the lock on the boot but try pushing down on the boot when you push the button in.
DemonDaz
Post Wed Nov 16, 2005 10:44 pm
I had a problem with this on mine, I had to put the key in the unlock position in the boot lock, I then pressed the button to lock the car doors with the key in the boot lock. Next unlocked the doors again and magically the boot opened!
Weird but may help
m3ben05
Post Wed Nov 16, 2005 10:47 pm
Thanks mate, il give that a go in the morning, its too damn cold now :(
dazleeds
old skool raver
old skool raver
Post Wed Nov 16, 2005 10:48 pm
give the key a good jiggling whille tryin to turn mine used to do this all the time
if ya manage to get it open give the whole mechanism a good greasing up sorted mine
www.oldskoolfantasy.co.uk
