Adjustable fuel pressure regulator/gauge setup
andy523
Mon Jun 18, 2012 12:42 pm
i have a bmw e30 325i and fitted a fse power boost valve, induction kit and mild ecu chip, do you know what bar i need to set the regulator at with a gauge at idle. At the moment i have it 2.5 bar at idle
zaust
Zone day release
Mon Jun 18, 2012 12:50 pm
Get rid of it and put the o/e one back. They don't hold high enough pressure at high revs.
M30 Tech 1 Touring on gas.
andy523
Mon Jun 18, 2012 12:55 pm
not what i wanted to hear Zaust, i will give the adjustable a go if i can get the right settings first
zaust
Zone day release
Mon Jun 18, 2012 1:44 pm
Set it to 3 bar on idle. You will notice more torque if you put the standard air box back too.
andy523
Mon Jun 18, 2012 1:48 pm
i tried 3 bar but seems to run rich, but will try it for a while. thanks
Mon Jun 18, 2012 2:10 pm
Zaust's first reply was the correct one!
andy523
Mon Jun 18, 2012 3:30 pm
why do they make these then if they are supposedly no good.
winx
Mon Jun 18, 2012 3:37 pm
To sell to people who believe the marketing and make a healthy profit :) A lot like a huge amount of other aftermarket companies...
Jim320i
E30 Zone News / COTM Team
Aftermarket parts are made to sell on for a profit... BMW do not endorce these parts.
They majority aren't made with performance in mind, more, sales amount. Just because a K&N Filter might work well on one car, doesnt mean they work well as an upgrade on all cars. The original design was designed for a reason :cool:
Hoobs
Tue Jun 19, 2012 9:10 pm
There are also cases of eBay jobbies failing and squirting fuel all over your engine - this is not a good thing.
Rally Prep - Cornwall
ARM BMW & Motorsport
2002
E30 M3 2.3 - Alpha N, C/F airbox etc
HairyScreech
Wed Jun 20, 2012 4:42 am
Adjustable pressure regulators should NEVER be anywhere near a standard engine, unless there is a very good reason to adjust the fuel pressure (trying to squeeze a bit more from under size injectors) then the stock item is the best bet.
