Its done 116000 miles and has full bmw service history.
A few questions i could do with some enlightenment on.
1)its lumpy, almost misfiring on idle and has a hesitation when you stab the throttle down, got a coolant temp sensor, sparkplugs and throotle position sensor on the way so hope its one of these. I have check for a vaccume leak and found nothing.
2) it knocks over bumps at the front but these is no play in anything but will be changing the anti-rollbar bushes as a little split, previous owner said its the top mounts? could this be?
3) gearstick is floppy but goes in all gears fine, is this just a matter of changing all the linkage?
4) sometimes when at low revs on light throttle the car starts to shake violently forward and back and was thinking the doughnut on the prop but also think it might be to do with the rough idle, maybe a missfire?
5) the brake pedal is long, have adjusted shoes at the back which has helped alot but still halfway down the pedal?
I know im asking alot but to be honest it drives lovely compaird to new fluffy cars
