Help speedo issue
bhaza
Post Thu Jun 07, 2012 7:12 pm
Hi when driving car the speedo will stop working it sometimes bounces and then just starts to work again anyone have any ideas as to what can cause this please?
rich318i
Post Thu Jun 07, 2012 7:17 pm
not had that problem let myself YET! lol
toby
Post Thu Jun 07, 2012 8:44 pm
Often a break in the speedo wiring which ends in a little plug on the differential. Have a little look and check the plug/wiring is not loose or damaged.
Post Thu Jun 07, 2012 9:40 pm
The break in the wire is often not visible, as the cause is a change in the crystalline structure of the copper conductor of the wire caused by vibration from the diff. This makes the copper brittle, and the wire breaks inside the plastic sheath, without any damage to this sheath.
The break can be found by gently stretching the individual wires, but it's important that at least the last 300mm of wire to the diff. is replaced, complete with plug, as any repair will still leave the remaining copper in the brittle state. A suitable plug and length of wire can be found around the headlamp area on a scrap E30 loom, or a repair cable can be bought from BMW.
jmc330i
Post Thu Jun 07, 2012 9:54 pm
bhaza wrote:Hi when driving car the speedo will stop working it sometimes bounces and then just starts to work again anyone have any ideas as to what can cause this please?
Does the odometer still turn when the speedo stops?
I'm having this problem with mine, but with the odometer still working I'm guessing its a problem with the clocks, rather than the usual wiring at the diff.
James
'91 325i Sport
'93 318i touring 16v
Post Thu Jun 07, 2012 10:02 pm
Speedo and odometer circuitry are all contained on a small circuit board behind the speedo, so your problem is most probably here. It's quite common for the solder holding the pins which plug the speedo into the main circuit board to crack and cause an intermittent speedo, but I'm unsure if any combination of cracks can kill the speedo and leave the odometer working.
bhaza
Post Fri Jun 08, 2012 9:12 am
Just wondering if there is a write up on this topic?
TheMoney
Post Fri Jun 08, 2012 3:02 pm
I had this and I just cleaned up the diff connector with WD40 and it has been fine since. So see if you can get away with that before cutting wires.
