87 320 convertible floor rust,can i......
lamby
got m.o.t on monday and have found a round plate in the floor behind drivers seat is hanging out and rusty! can i cut it out and rivet a bit in then underseal it or does it need to be welded? reason being i cant weld or know any one who does.....
Grrrmachine
- E30 Zone Wiki / Team Member
Does it look like this?
If so, you can get them from BMW. They're not welded in, they twist and lock in, and are then covered in stone-chip and seam sealer.
If your MOT tester sees a single rivet anywhere, he'll fail you.
lamby
it does but it,s rotted all round,well enough for me to leave it alone.only place too! well that,s another one gone then! thanks for quick reply
lamby
right i,ve pulled the plate off and it is that that has rotted except for a small bit i can rust convert and seal it,any one know pt number for plate as i can,t find it on oem?
Grrrmachine
YOu don't need to start two threads on this. I've answered in your other thread.
