m60 gearbox
sparkyE30
will a manual gearbox from an E39 535 v8 fit the the 4 litre m60 engine?
HairyScreech
Yes should do.
The v8 engines share a bell housing and crank pattern across most of the range.
e21Jason
M62 to m60 should work, you just need to check the position of the crank sensor on a m62 it is on the flywheel and m60 on the crank damper from memory
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
Z3M Coupe for sale
69 Alfa spyder
sparkyE30
so what would i need to do if i put an m62 box onto the m60 engine?
i have a new unused 530 v8 clutch kit for £100.
