Hole in Wing = MOT fail???
Razza
Tue May 29, 2012 9:19 pm
As above I have a rust hole in the passenger side front wing from the top of the side skirt along the arch to just below trim below the side repeater, probably about the size fag packet side on - driver side is fine.
Is this an MOT fail?, car is due an MOT to sort out a few minor niggles then the plan was put it into the bodyshop to replace this panel and sort the bodywork
jonny323i
Tue May 29, 2012 9:21 pm
it could be if its seen as a jagged edge so just fibre glass it temp then it will pass
Touring for life
Tue May 29, 2012 9:27 pm
As above, or gaffa tape it.
mcbonio
Tue May 29, 2012 9:28 pm
They will fail corroded bodywork if it's structural or deemed a danger to people FYI.
rich318i
Tue May 29, 2012 9:31 pm
GAFFER TAPE THE HOLE it will pass
Tue May 29, 2012 9:39 pm
Ive had cars pass with holes in the wings before no problem, if you think the tester could be fussy then just tape over it as advised
jonny323i
Tue May 29, 2012 9:45 pm
most mot testers will tell you if it cant be seen they cant fail it hence my old sooty van was more gaffa tape than metal for some time lol
Touring for life
Barx325i
Tue May 29, 2012 9:46 pm
gaffer taping a non structural void WILL pass, even if a vosa official is present, it's crazy
Razza
Tue May 29, 2012 9:57 pm
Cool, thanks :cool:
