inlet manifold pipe
jonny323i
Post Tue May 29, 2012 9:18 pm
iv had my inlet manifold off and replaced and im not sure if it was there before or not but iv now got a weird hunting at idle and after discussing this with some who had a similar problem it could be worn or missing orings around the pipe that is between the inlet manifold and the bottom of the block items 9-12 in the picture above.
Iv sourced some new washers and orings etc could someone confirm for me where exactly do i put the washers, orings etc are they fitted in the inlet manifold end and the block end or what???? cheers in advance
Touring for life
steve_k
Post Tue May 29, 2012 9:26 pm
They go on the pipe at the bottom of the spring.
jonny323i
Post Tue May 29, 2012 9:31 pm
it lists 2 washers and 2 orings so which order do you fit them and is there any gasket fitted between the bottom of the inlet manifold and the pipe
Touring for life
steve_k
Post Tue May 29, 2012 10:06 pm
It's been a while since I did mine but IIRC it's 1 O ring & 1 washer on the bottom & 1 O ring & 1 washer on the manifold end but thats as much as I can remember.
jonny323i
Post Tue May 29, 2012 10:21 pm
great thanks to clarify does the oring go in the whole first then the washer on top
Touring for life
**BANNED**
Post Wed May 30, 2012 9:20 am
jonny323i wrote:great thanks to clarify does the oring go in the whole first then the washer on top
That's right,the spring presses down on the washer.
Easy way to re-assemble is to compress the spring with a couple of tie-wraps,assemble to the block,then slide the manifold on,locate the top of the tube and finally slice the tie-wraps.
Post Wed May 30, 2012 9:27 am
Make sure the O rings and the recess into which they fit are lubricated with a drop of oil before assembling.
jonny323i
Post Wed May 30, 2012 1:45 pm
Marvelous thanks
Touring for life
AlpineCab
Post Fri Aug 10, 2012 7:22 pm
a useful post because I'm in the middle of taking the head off on my motor and wasn't expecting to find this pipe thing attached to the inlet manifold...
When i dismantled it, looking in the tube was like looking inside a jar of salad cream.
So my question is, does the mayo inside this tube signify an expected by-product of a blown cylinder head gasket, or does it point to a different prob altogether?
Post Fri Aug 10, 2012 7:53 pm
Mines still not right Jonny - I can see me having to take the fooker to bits again soon :banghead:
jonny323i
Post Fri Aug 10, 2012 9:25 pm
what have you done so far matey
Touring for life
Post Fri Aug 10, 2012 9:47 pm
jonny323i wrote:what have you done so far matey
Bought an o-ring set from BMW - there was 4 in the bag but I only took 2 off and replaced them
Pig of a job to do in my small garage too
I need to have a proper got at it with carb cleaner to try and find the air leak
jonny323i
Post Fri Aug 10, 2012 9:48 pm
did you get the washers, spring and pipe too
Touring for life
Post Fri Aug 10, 2012 9:51 pm
No i just re-used the washers, spring and pipe - I guess the spring could be weak ?
jonny323i
Post Fri Aug 10, 2012 9:53 pm
when i did mine i replaced everything and it wasnt too exspensive one thing i did find i thought it would then pop up into the manifold on its own but after a quick twist it went further up into the manifold even with a new spring
Bring all the bits and if i manage to make it might give it a go while its still light
Touring for life
Post Fri Aug 10, 2012 9:54 pm
Don't worry mate I'll sort it - just try and get there tomorrow :D
AlpineCab
Post Fri Aug 10, 2012 10:01 pm
willnz wrote:
AlpineCab wrote:a useful post because I'm in the middle of taking the head off on my motor and wasn't expecting to find this pipe thing attached to the inlet manifold...
blown gasket/cracked head
Good (in a perverse sort of way), that's what I thought it was, hence half way through replacing head with a spare.
Sounds like this pipe thing is a bit of a saga though....
**BANNED**
Post Sat Aug 11, 2012 2:36 am
Pipe is part of the crankcase breather system,so it is not unusual to find it full of mayo....the bloody stuff has to accumulate somewhere...
As I posted ages ago further up,compress the spring with a couple of tie wraps,this aids the re-build!
Youth is wasted on the young.
AlpineCab
Post Sat Aug 11, 2012 10:00 am
daimlerman wrote:Pipe is part of the crankcase breather system,so it is not unusual to find it full of mayo....the bloody stuff has to accumulate somewhere...
good news... new rubber seals and gaskets it is then...
