Need some help on this
Got a drain on the battery on the 325, nothing is knowingly left 'on' and alarm is switched off, battery was new 3 months ago so that's not a suspect...
Sitting for 4 days and it won't turn over, needed jump starting.
Where to look?
Any tips gratefully accepted.
Stu
Battery drain
bigwinn
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
Grrrmachine
- E30 Zone Wiki / Team Member
bigwinn
cheers
bigwinn
Update
The wiki guide was invaluable
Ammeter across the terminals, reading of 0.7 rather than 0.3 and was fluctuating between 0.7 and 0.2...
until fuse 24 was removed
so as that powered the radio thats been disconnected as a starter for ten- however as it fluctuated I suspect the aftermarket alarm- which was not armed at the time of the test
thoughts?
Stu
thoughts?
Stu
DHFiS
I had the same issue with mine. The alarm, even when unset was draining the battery. Once the old alarm was removed the problem never reoccured.
bigwinn
Alarm is coming out....
