help needed abs, alternator, engine warning lights on
Bally
hi went to start the car (j reg 325 auto cab) and the above 3 warning lights are on , seems strange all 3 coming on at once any ideas what I should check for Thanks
Bally
by engine light I meant ignition light.
thanks
thanks
- **BANNED**
Did they go out when the engine started?
Youth is wasted on the young.
Bally
hi.
no when the engine is running the lights stay on , they are not going brighter when revved will double check
Bally
hi just to clarify.
the lights that are on are
the one with braks shoes and exlamation mark, abs, and the light with the battery.
when revved the lights do not go brighter
Any help would be appreciated
Bally
thanks ,
checked belt , it is ok , suspect alternator but would this cause abs light to go on ...
any one else any ideas .
Bally
just checked earth, disconnected and reconnected battery , took for a 0 minute run today, and also been starting car approx ten times , ran with lights on no dimming or brightening with revs, battery still not flat .
also just noted the handbrake light is staying on (so 4 lights on in total) the handbake light dims slightly when handbrake taken off.
lights come on with ignition , stay on while turning engine and stay on once running , only oil light is going out as it should , seems en electrical issue.
any help appreciated.
thanks
thanks
kam-325i
ABS light could come on due to an Undervoltage.......
Bally
Hi Kam 325i
so if the alternator is not working properly it could cause issues to abs light.
Think I may have to get it to the local bmw specialist to test alternator. any othes suggestions
Thanka
Thanka
kam-325i
yes, i think that if the ABS ECU see's an undervoltage, it will show an error.
EDIT:
Dose the car drive ok ?
Do the other lights on the dash work ok, indicator lights, rear fog light light and so on ?
EDIT:
Bally
hi yes everything else is fine car drives fine, thats why i think it is an electrical fault , battery not going flat so may be the alternator is charging but not fully (if that is possible), all other dash lights are ok I have reset service lights and that was ok as well.
kam-325i
might be a short-circuit on the printed circuit film on the back of the instrument cluster.......
Bally
so remove cluster dust off and look for any short circuit (burn marks)
kam-325i
thats where i would start, never overlook the simple things.
bmw444
Hi
i just wondered how you were going solving your warning light problem? My 1990 325i has just started having the same symptoms.
The warning lights referred to in this thread are required to have a 'test' function to check that the bulbs are working.
The electronics in the instrument cluster turns the bulbs on when the ignition is switched on, and off again (if there is no fault) when the voltage on the small (blue) wire from the alternator reaches a certain voltage. If the alternator voltage on the blue wire falls below this critical voltage at any time when the engine is running, such as in a near stall, the lights re enter the test mode.
The most likely cause of this fault is the alternator, although it doesn't necessarily affect it's charging of the battery, and a simple DC voltage check on the blue wire may not show up the fault if a diode has faled.
