Eeek.....Eeek.....Eeek.....Can Wheel Bearings Squeak ??????
E30Mike
Post Sat May 12, 2012 11:21 pm
I've had a noise from the front offside for the last few months which is getting slowly worse let alone annoying
It only happens when the car is moving and turning to the left just like a failing wheel bearing can, except instead of the rumbling sound its a repetitive squeaking noise.
Any ideas would be appreciated before I go to the expense of a
new bearing and find it isn't in fact the cause.
Many thanks
318is1990
rich318i
Post Sat May 12, 2012 11:25 pm
low brake pads id put money on it
E30Mike
Post Sat May 12, 2012 11:33 pm
Checked that, calipers been off and cleaned, pads between 1/4" and 3/8" left
318is1990
rich318i
Post Sat May 12, 2012 11:39 pm
its not the heat shield is it ? take it to kwick shit and get them to do a brake inspec on it. its free any way and while its up in the air check it all out your self see if there is any play or noise from the hubs
E30Mike
Post Sat May 12, 2012 11:49 pm
Not the heat shield either,
If you spin the wheel you can only really hear the pad/disc noise unlike the bucket of bolts I had on the nearside.
318is1990
rich318i
Post Sun May 13, 2012 12:08 am
anti-roll bar popped out at the rear ? mine did and made a sqeek as it was rubbing on the wheel arch, its a smiple one mate but i know what you mean its just gets on your nerves
Post Sun May 13, 2012 12:13 am
not sure what year your car is but I know it will be 20+ years old,
a set of new rear wheel bearings won't do any harm or break the bank :D
E30Mike
Post Sun May 13, 2012 12:18 am
Mot'd 3 weeks ago so no bits loose just slight play in front ball joints
I can't see it being the ball joint though as its such a regular sound
hence me confused :? :?
Thanks for the input :)
318is1990
E30Mike
Post Sun May 13, 2012 12:20 am
e30topless wrote:not sure what year your car is but I know it will be 20+ years old,
Its a 318is and defo the front
318is1990
rich318i
Post Sun May 13, 2012 12:40 am
you drive it mate and the owners knows best
E30Mike
Post Sun May 13, 2012 2:50 pm
I don't know about me know but line the kids up in a car park then drive past them several times you soon find out where it coming from.
Shame they can't tell whats making the noise :D
318is1990
