Thanks Bill, i did notice the pulley had worn through it abit when i took the pump out, putting it back together i couldnt find anything it clipped into so i put it over the top of the hose that goes to were the thermostat is to keep it away from the pulley an it was working fine last night, had the misfiring problems this morning, just had a look at the wire an i broke the yellow wire inside that the pulley has worn into, was very brittle, anyway, started it up with the broke yellow wire, it just revs like the accelerator is flat to the floor, misfire has gone though
Dont actually know what to do, i have to spend another £100 on ht leads because i cant find the pick up sold separate, still got the heaters blowing hot, temp gauge reading cold problem which has me stumped? Which i cant do nothing about till ive bought the leads anyway
Spend sooo much money getting this car running right, about a week after loosing my job the exhaust fell off an its gone downhill from there, fix one thing an another thing breaks instantly.
I might just burn it an buy a micra
