Weird noise
stu328is
Post Thu May 10, 2012 10:53 am
I know i shouldn't do it but on occasions i give the motor some beans in the wet and get the wheels spinning up quite hard sometimes up through second gear but a couple of times now the back end seems to jump (bounce?)and i get a quite a loud bumping noise coming from the rear suspension.
Hard to describe really as it doesn't always do it but what could it be, knackered shocks, bushes?
it's all standard by the way
Any ideas chaps?
E36 328 Sport
E30 325i
Mk2 Golf 8v
Rtaylor2208
Post Thu May 10, 2012 10:56 am
Bushes is probably the most likely culprit. Really you need to get the car up off the ground and inpect the condition of them.
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu May 10, 2012 12:03 pm
What you're experiencing sounds like wheel tramp, and is caused by loose suspension components.
Biggest culprit is the subframe bushes, which if original will be utterly shagged by now. It's a good idea to do all the rear bushes in one hit, and a full list with How To guides is in the Wiki:
http://www.e30zone.net/e30zonewiki/inde ... ushes#Rear
stu328is
Post Thu May 10, 2012 1:17 pm
Nice one, will look into getting them done
cheers
E36 328 Sport
E30 325i
Mk2 Golf 8v
