M50 conversion E30 320i flywheel/starter fit?
paulyboy
Post Mon May 07, 2012 1:20 pm
I'm about to do an m50b25 swap into my e30 1989 320i.
I know you are best to use the m20 modded flywheel and starter, my question is, are 320i and 325i flywheels/starters identical? I'd like to use them off my current motor.
Post Mon May 07, 2012 1:45 pm
Identical. Only the spring in the clutch cover plate is different.
