325 timing belt
jimmypee
Sun May 06, 2012 11:52 am
I,ve seen the thread. I take it thats for a manual there are 2 pipes going into my rad are these cooling pipes for the auto trans oil. Do they just screw out. Also do most people take the bonnet off.
Topblag
Sun May 06, 2012 12:19 pm
Bonnet stays on. Airbox, radiator and viscous fan off.That gives you all the access you need. Just disconnect the auto box cooler pipes from the rad and put then in something to catch the oil drips.
The unscrew the nuts and pull them out of the radiator.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
jimmypee
Sun May 06, 2012 12:39 pm
Nice one.
jimmypee
Sun May 06, 2012 8:20 pm
Just reading the thread it's not clear whether you leave the tensioner loose so it tensions belt as it stretches or if you tighten it back up. Can anyone answer the question
Rtaylor2208
Sun May 06, 2012 8:26 pm
Once you have removed the Old belt you need to push the tensioner hard up against the spring then lock it in position tightening the mounting nuts. Once that's done fit the belt, crank first then intermediate wheel, then cam and finally onto the tensioner.
Once that's done loosen the tensioner bolts to allow the spring to tighten the belt.
With the belt now tight, tighten up the bolts. Then reassemble everything.
Having just done this myself on a 325 auto on frIday I can confirm that it's a horrible job to do.
Sun May 06, 2012 9:39 pm
Rtaylor2208 wrote:Once you have removed the Old belt you need to push the tensioner hard up against the spring then lock it in position tightening the mounting nuts. Once that's done fit the belt, crank first then intermediate wheel, then cam and finally onto the tensioner.
Now turn the engine,by hand with a 22mm spanner on the crank bolt, two full turns in the forward direction, then slacken the tensioner bolts and allow the spring to tension the belt again while still applying a little pressure to the spanner, to ensure that the tension side of the belt is actually under tension. Tighten the tensioner bolts again.
jimmypee
Sun May 06, 2012 10:02 pm
did you replace the tensioner or just the belt. Mines had the belt done loads of times but not sure if the tensioners been done
Rtaylor2208
Mon May 07, 2012 12:23 am
^^^^ Brian is the voice of expertise here. I rePlaced the tensioner also as it was literally £10 more than the belt, for at least 4 Years / 40000 miles of peace of mind it was worth it.
Mon May 07, 2012 7:24 am
jimmypee wrote:did you replace the tensioner or just the belt. Mines had the belt done loads of times but not sure if the tensioners been done
ECP sell a timing belt and tensioner kit - not expensive and made by Contitech who manufacture the genuine belts for BMW.
For what they cost you may as well change the tensioner with each belt change.
Mon May 07, 2012 9:38 am
Depends to a large degree on whether the belt is changed as a result of mileage or time.
On a garage queen that only does 1000 miles a year, the belt should be changed every four years, but there's little point in changing a bearing that's done just 4000 miles.
Note that there was a duff (M20) tensioner supplied at one time, marked Z139???, IIRC, and this should be changed on sight. The centre pin on these becomes loose, allowing the tensioner to run at an angle, and throwing the belt against the outer cover.
jimmypee
Mon May 07, 2012 12:06 pm
Yeah it's only 45 quid for the continental belt with tensioner so will do both
