Fuel Injector HELP PLEASE!
Gavla
Post Sat Apr 21, 2012 4:38 pm
Ok so I finally had some spare time to change my fuel injectors, or so I thought.
I managed to get everything unscrewed, pipes blocked off etc.
Problem is for the life of me I could not get the fuel rail out because the injectors would not "pop" out. All the literature says a bit of force is needed, but nothing I did helped, I stopped only because I was worried I might break something.
Is there a trick to this? Can the seize up? How much force is a "bit"?
Thanks in advance for any advice and help.
d1mkaz
Post Sat Apr 21, 2012 6:41 pm
they do need a bit more force, I can't tell how much exactly, but a bit more than you used :)
please can someone confirm?
**BANNED**
Post Sat Apr 21, 2012 10:08 pm
Injectors are held in place by a rubber O ring..... :D
Youth is wasted on the young.
Gavla
Post Sun Apr 22, 2012 12:15 am
So I am gathering I wont break anything?
I will give it another try tomorrow if I have time.
Gavla
Post Sun Apr 22, 2012 1:18 pm
So I got the refurbed injectors in today, yip, a little bit more force was necessary. Hopefully this will help my fuel consumption?
