Camber Adjustment
SPIROS
how do you go about adjustin the camber on these bad boys, just recently bought a e30, think its lowered 40-60 m m, on 17's, think camber hasnt been changed tho, cheers
astondg
Front camber shouldn't be a problem, unless you want more. You can buy fronts strut top mounts that are adjustable or I think there is a factory part that is made for fixing accident damage that you can use too.
Rear camber can be fixed with adjustable trailing arm bushes.
A bit of camber can help handling but it wears the tyres more quickly and uneavenly. It is up to you what you can put up with.
Aston
Aston
BMW E30 323i with some stuff
1:21.67 @ Morgan Park Raceway
