nearly there
xavier
I put in the new water pump, timing belt, tensioner, belts and some other odds and ends, all markings still perfectly lined up, bolted it all back together. Ah! the starter motor starts it all but it will not keep spining of its own accord. Any ideas?
Grrrmachine
- E30 Zone Wiki / Team Member
Do you mean it won't idle, or it won't fire even if the throttle is held down?
xavier
wil not fire up
Grrrmachine
Have you confirmed the presence of spark and fuel? You can work through the Troubleshooter if you want:
http://www.e30zone.net/e30zonewiki/inde ... oubleshoot
That'll do until you tell us what engine we're dealing with
Jos
'94 e36 tree climber
xavier
It's the 323i. The m20 motor
Grrrmachine
Ah. 323i will have earlier engine management than Motronic 1.3 - you should have the two CPS sensors in the gearbox/flywheel rather than at the front of the engine. If you've disturbed either of these, you won't have any fuel coming in.
Do you have spark? Have you done the bulb-on-coil test yet?
