gearbox problem and possible swaps
e30pum
Post Tue Apr 17, 2012 7:23 pm
hi i am a new member to the forum i have a 318is and recently my release bearing went on my car. I waited until it got bad and and went to replace with new clutch. when removing the gearbox, just behind the fork (not sure what it is called) fell apart and was instructed i need a new gearbox or get old one repaired. bmw wanted £140 for part so started looking for second hand gearbox. does anyone know if e36 box will fit? i know there a slightly different engine, or will a 316 box fit? many thanks ben
Jos
Post Tue Apr 17, 2012 8:40 pm
box from the M40 engine will fit ok (318i, 316i). e36 box is different, bolts up but you'll have to fab the linkage as it's different. Ratios are also different iirc
'94 e36 tree climber
HairyScreech
Post Wed Apr 18, 2012 12:15 am
Can you get a picture of what has failed?
