Back of seat
dizz
Post Thu Nov 10, 2005 9:27 pm
After reading about the screws inside the front seat that if loose make you lean to one side when driving, i would like to adjust mine as this may be whats wrong with mine,
so how do i get the hard back pannel off of the front drivers seat without bending/breaking it.
if any one can help then i can stop driving at an 45 degree angle.
bmwe30mtech
Post Thu Nov 10, 2005 9:33 pm
I think it should just pull off, but do it carfully . Work your way arround the edge, but perhaps you should wait for another reply to check. :thumb: I need to do my seat as well! :mad:
Post Thu Nov 10, 2005 9:35 pm
Think I better reply quickly before you break it. Tilt the back over as far as it goes, and you will find two small self tappers right at the bottom. Remove these, pull the bottom edge back and unhook the top.
smithy318i
Post Thu Nov 10, 2005 9:36 pm
2 small screws at the bottom of the panel.
tilt the seat forward for best access.
it just falls off then.
dizz
Post Thu Nov 10, 2005 9:39 pm
I tried to do that but it felt like too much pressure, so i chicken out, and came back to the good old forum :D
dizz
Post Thu Nov 10, 2005 9:44 pm
Ok thanks, didnt know about the screws, will try this tomorrow, forum to the rescue again :D
bmwe30mtech
Post Thu Nov 10, 2005 9:51 pm
Well there you go, glad i said to wait for a second opinion!! I can try mine now. :oops:
dizz
Post Fri Nov 11, 2005 6:00 pm
I got the back off the seat but the big screws in side were tight, so this is not the problem, the lady who owend the car before me was a very large lady, no i mean a very very large lady and she may have damaged the seat, so all i can think off is to swop the two front seats over as im usualy in the car on my own.
is it possable to swop and how do i do it?
bmwe30mtech
Post Fri Nov 11, 2005 6:18 pm
The seatbelts and release handles will obviously be wrong if you do a direct swap, but i think i have read somewhere that the frames can be swapped, but this may be whats broken!?
