Evening all
The time has come, can't put off anymore, the rear shoes need changing on the 316i.
I've checked the wiki and mr Haynes. Anyone got any top tips before starting?
Got new shoes and drums.
Cheers in advance
Stu
Rear shoe replacement
bigwinn
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
Drums are a piece of p1$$
Probably worth taking a pic once you get the drum off so you can see how it all fits back together.
Refitting is the reverse of removal
Slacken the handbrake cables right off at the handle before you start, and adjust the shoes up properly before touching the adjusters at the handbrake lever when you've finished.
bigwinn
Top tip on the photo Rob, cheers
did you get a new spring kit with the shoes ? chances are you may need them
bigwinn
No, do I need it cos I'll lose them or because they will be fooked?
They could be rusty old scrap that could break on removal.
bigwinn
Got it, will get a set before removal
You'll need a good set of pliers/grips to get hold of the springs for removal/refitting.
Photo before you start will show you which way round they all go.
Best thing, apart from the correct special tools, is a length of thin, strong wire, hooked around the end of the spring, that you then pull, either by hand or with pliers.capri_rob wrote:You'll need a good set of pliers/grips to get hold of the springs for removal/refitting.
I usually use a short piece of serrated wire intended for cutting through the sealant that bonds in windscreens.
