I found this pipe in my engine bay and have no idea where it goes
I'm wondering if it should go here but where does the other end go , i have the pipe from the dizzy to carb and carb to bottom of the air filter and a pipe from the the air filter duct
These look like the bits associated with working a flap in the intake of the air filter, which switches the incoming air source between from behind the RH headlamp to warm air from around the exhaust manifold.
