mot fail, rear fogs
mrb27
Post Thu Mar 22, 2012 12:11 pm
hey all, just had my car mot'd and its faild on the basis that the rear rogs dont work at all, nor does the light on the dash when turned on, checked fuses and all ok there, buld in dash is in tact, where do i start?
thanks all
Uploaded with ImageShack.us
Topblag
Post Thu Mar 22, 2012 12:40 pm
I would suggest swapping the switch that activates them and seeing if that makes a difference.
The only dependancies the fog light has is the driving lights being on and the fog light button pushed in IIRC.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Mar 22, 2012 12:41 pm
The switch, I'd expect. Pull it out and bridge the terminals to see if a) the dash bulb glows b) the lights themselves glow.
mrb27
Post Thu Mar 22, 2012 12:57 pm
ok cool ill try that, what 2 do i bridge? there are about 4 wires iirc
Post Thu Mar 22, 2012 1:36 pm
Bridge 2 (yellow/black) and 4 (grey/purple). Dipped headlamps or front fogs and ignition has to be on.
If they don't work, feed 12 volts directly to pin 4.
mrb27
Post Thu Mar 22, 2012 3:05 pm
sorted :) wasnt sure what to bridge so i just took a look and it seemed there are 2 wires on each side of the switch, so i took a guess and connected both wires that was on the rear fog side of things and it worked. dash light came on and so did the rear fogs. thanks for the info guys :D
