High oil consumption
paul92
Post Tue Mar 20, 2012 8:29 pm
Having good compression of around 160lbs on all cylinders, wanted to refresh to head, ran fine on dyno and on track for half an hour, but used a sump full of oil, blowing blue smoke.
Don't think it can br the rings from previous compression test.
Anyone got any ideas ? :mad:
kam-325i
Post Tue Mar 20, 2012 8:32 pm
What engine is it ?
gooner1
Out humping Reindeer
Post Tue Mar 20, 2012 8:36 pm
Valve stem oil seals :?:
kam-325i
Post Tue Mar 20, 2012 8:41 pm
gooner1 wrote:Valve stem oil seals :?:
That normaly cause's blue smoke just after the engien is started, i cant see that much oil passing thru the seals in an hour, especially when there is no pressure behind it.....
paul92
Post Wed Mar 21, 2012 11:12 am
It's A 320, the head was a low mileage 80k, had a skim and a new cam only.
kam-325i
Post Wed Mar 21, 2012 9:50 pm
i would suspect a crack in the head somewhere.......
Ant
Retired Team Member
Retired Team Member
Post Thu Mar 22, 2012 6:02 pm
defective crankcase ventilation will make the engine burn a lot of oil.
