Rough Running when cold..........
Rich25i
Post Tue Nov 08, 2005 3:45 pm
Hello again my 325i 89 has now developed a cold running problem.
just went to start it and it was running a bit rough. waited till it warmed up
and it cleared up a lot but still feels wrong. im i right in thinking this is the blue temp sensor or is it something else?
Thanks in advance
RICH
jonbuoy
Post Tue Nov 08, 2005 3:51 pm
Have you gave anything a spring clean lately?
I've asked the same question myself about the Blue Temp Sensor and it is usually the case but mine is the 318i so i can't garruanty anything.
I think you also have an Air Temp Sensor which is located under the inlet manifold, that also could be faulty.
Good luck :D
Also, are you goin to the Lakeside meet on the 26th at McDonald's?
More the merrier(sp)
Rich25i
Post Tue Nov 08, 2005 3:57 pm
Hi thanks
Ok i wll change the blue one first and see if that helps.
Might go up there depends if i am off work. Been trying to go to a meet for a while but i seem to be on call every time one is arranged :(
Thanks again
