Motronic 1.3 Engine fault codes
Nightshift
Post Sat Mar 10, 2012 1:20 pm
Trying to get the ECU fault codes by following the process described below, but getting diddly squat, not even a '1444'; the engine check light just stares back blankly (well, not literally).
http://www.verrill.com/car/idle/e30_idleproblem.shtml
Anyone gone through this process and successfully got the codes? Any pointers?
Post Sat Mar 10, 2012 1:31 pm
Where in the world are you? Unless you have a US spec. E30, you won't have the engine check light fitted.
Nightshift
Post Sat Mar 10, 2012 1:45 pm
Brianmoooore wrote:Where in the world are you? Unless you have a US spec. E30, you won't have the engine check light fitted.
Cheers MrMooore
So, I'm mistaking the flashing engine check light in the centre of the instrument cluster for something it isn't? That would explain a lot.
Is there no way of retrieving the fault codes on a european spec car?
Post Sat Mar 10, 2012 1:49 pm
The relevant wire for the engine light is usually present in the engine loom as far as the 20 pin C101 engine loom plug and socket, next to the fusebox. It's a plain grey wire, and you connect a 2.2W or so 12 volt bulb between it and 12 volts ignition live.
Whether the code test works or not, I've no idea.
Nightshift
Post Sat Mar 10, 2012 1:50 pm
Brianmoooore wrote:The relevant wire for the engine light is usually present in the engine loom as far as the 20 pin C101 engine loom plug and socket, next to the fusebox. It's a plain grey wire, and you connect a 2.2W or so 12 volt bulb between it and 12 volts ignition live.
Thanks mate.
