Remove and Refit of Tech 1 Rear Bumper
Rtaylor2208
Post Mon Mar 05, 2012 11:49 am
Hi Folks,
The tech 1 rear bumper on my cab has about 1 cm of movement vertically so something seems to be loose.
Is it just the two bolts within the rear arches that need to be removed to take it off?
Thinking I'll take it off and try and figure out whats wrong underneath.
zaust
Zone day release
Post Mon Mar 05, 2012 2:07 pm
You also will need to remove the carpet from the inside of the rear panel and the othe bolts will be revealed to you. (under the light's )
M30 Tech 1 Touring on gas.
Rtaylor2208
Post Mon Mar 05, 2012 2:28 pm
Zaust, that you very much, I was crawling about under the car yesterday and it had me defeated. Nice One
zaust
Zone day release
Post Mon Mar 05, 2012 3:29 pm
10mm iirc x
