325i tappet adjustment settings?
urfy
Post Thu Mar 01, 2012 10:16 pm
Hi just nef a quick guide, does anyone know the factory settings for the tappets for 325i? Also would it be the same for a cam which has covered 150k+ miles?
Cheers.
89 BMW E30 325i Sport
93 BMW E30 325i Cabriolet
89 Mercedes 190E 2.5-16 Cosworth
86 Mercedes 190E 2.3-16 Cosworth
96 Mercedes E320 CE Sportline
88 Nissan Bluebird ZX Turbo
89 Nissan Bluebird Executive Turbo
kam-325i
Post Thu Mar 01, 2012 11:15 pm
0.30 is when the engine is warm, and 0.25 when the engine is cold.
set the same regardless of mileage...
urfy
Post Thu Mar 01, 2012 11:23 pm
kam-325i wrote:0.30 is when the engine is warm, and 0.25 when the engine is cold.
is that both for inlet and outlet?
kam-325i
Post Thu Mar 01, 2012 11:27 pm
Both
urfy
Post Thu Mar 01, 2012 11:30 pm
kam-325i wrote:Both
cheers bud.
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Mar 02, 2012 6:39 am
Brian28
Post Sun Mar 04, 2012 7:16 am
Isn't the bigger gap with a cold engine, as it will tighten when everything expands with heat? Or is my logic back to front?
Post Sun Mar 04, 2012 10:12 am
Hot clearance is the greater one.
Your logic is back to front. Alloy and steel are both involved and alloy expands more than steel. Think about it, and it will become clear!
Andyboy
Alpina Colada
Post Sun Mar 04, 2012 3:32 pm
Do them stone cold, because it doesn't take long for the cam and bits to cool off with the cam cover removed. When they're cold, they're cold. Some 325i's like the exhausts set to 12 thou to improve the idle. It's also worth running a tiny drill (1mm) down the oil spray bar holes to increase the oil flow - this works well on cams that are a bit worn as yours possibly will be.
