M3 exhaust - how is it hung
Jozi
Post Tue Feb 28, 2012 7:13 pm
Has anyone got some pics showing how the backbox of an M3 is hung under the car?
There's a bracket between the tail pipes on my scorpion system which I'd like to use. Is this a better way of hanging it than using straps around the backbox?
Post Tue Feb 28, 2012 8:20 pm
It is if you also use the two mounts at the rear beam.
Check Dezzys thread as I reckon he has chosen the simplest way of mounting it
Jozi
Post Tue Feb 28, 2012 10:10 pm
Was going to make up a 2nd mount on the rear beam for it. I think Dezzy was going to use traps but I've not seen the outcome, will check his thread. The M3 mount seems like a solid mounting point though?
