Help with this part please - Thermostat Housing
tom325sport
Post Sun Feb 26, 2012 10:06 pm
The part below snapped off the bottom of the thermostat housing today! It connects to a small pipe.
It looks like it should be number 20 from here...
http://bmwfans.info/parts/catalog/E30/C ... ter_hoses/
But it is not listed. Any ideas what this part is and how I might get one.
oomz1975
Post Sun Feb 26, 2012 10:11 pm
Better of getting hold of another thermostat housing, my original one broke in the same place.
tom325sport
Post Sun Feb 26, 2012 10:14 pm
But the housing is fine - it's just that little 'L' shaped bugger that's snapped!
Are they not a separate part?
TPS
The Small Hose which supplies Coolant to the Throttle body, I think, comes off that pipe. New Thermostat Housing I suggest, would be the answer.
tom325sport
Post Sun Feb 26, 2012 10:29 pm
Can you tell if 320's have the same thermostat housing as a 325? M20 engine.
bodger
Post Sun Feb 26, 2012 10:59 pm
ECP do them or atleast they did 2/3 years ago when i bought one
Post Sun Feb 26, 2012 11:06 pm
/\ thats useful.
As said its part of the housing they corrode internally hence why they break off now. Its a lack of coolant changes that does it. Most second hand housings are similar. New one is the best fix really.
Get the hole tig welded up is another answer, then block off the pipe coming from the back of the block with a bolt. M8 thread i think. Its the pipes that head the TB, waste of time.
