got an odd problem with the brakes on my 325 tourer. At low speeds, less then 5mph probably, i get a weird pedal feel like the abs is cutting in, it feels like rubbing your thumb along a comb, and at the same time there is a 'sproingy' noise from the ABS pump area, a bit like when you spring a ruler off a table ...
in normal driving the brakes seem ok, but pulling up to a stop just before the car actually stops, is when the springyness happens. the car does stop, just with the weird feel, like if you try and brake on wet grass / snow etc.
sooooo, wheres the best place to start ?
presumably cleaning the toothed rings first would help, could the sensors themselves need cleaning or repositioning ?
none of the dash lights are on, and they all light up with the key.
cheers, Phil
