is this a 2.5 l ???
DazzyA
Post Sun Nov 06, 2005 8:47 pm
<img src="http://i24.photobucket.com/albums/c5/Da ... SIE018.jpg" alt="Image hosted by Photobucket.com">
thanks.
stevetigger
Post Sun Nov 06, 2005 8:49 pm
Linky no worky??
MISSY30
Post Sun Nov 06, 2005 8:51 pm
I think it's a 320i but only because of the battery being in the engine bay unless it's a Tourer?
This should work: http://i24.photobucket.com/albums/c5/Da ... SIE018.jpg
stevetigger
Post Sun Nov 06, 2005 8:53 pm
MISSY30 wrote:I think it's a 320i because of the battery being in the engine bay unless it's a Tourer?
I agree with that!!
DazzyA
Post Sun Nov 06, 2005 8:55 pm
I'm trying.
E30Mark
Post Sun Nov 06, 2005 8:57 pm
Picture is of a convertible....
Got a picture of the other-side of the inlet manifold?
PM for details
Simon
Post Sun Nov 06, 2005 9:02 pm
The inlet manifold is a 325i item.
Inlet manifold looks like 325, but that's not conclusive. Look above exhaust port 2 as I said.
DazzyA - Please don't start uneccessary new threads on esentially the same subject. This should have been added to your last thread, "engine size"
DazzyA
Post Sun Nov 06, 2005 9:16 pm
just took these in the dark.
<img src="http://i24.photobucket.com/albums/c5/Da ... mer023.jpg" alt="Image hosted by Photobucket.com">
why wont it work???????????????
DazzyA
Post Sun Nov 06, 2005 9:17 pm
Sorry Brian I'm new to this, just thinking I've been had over.
Post Sun Nov 06, 2005 9:20 pm
LOOK FOR THE LITTLE RAISED CIRCLE ABOVE EXHAUST PORT 2.
DazzyA
Post Sun Nov 06, 2005 9:21 pm
Yeah sorry Brian just saw your message on previos thread, wont happen again
darren.
DazzyA
Post Sun Nov 06, 2005 9:36 pm
Have looked above ports and there are no markings, the previos owner had a new bare cylinder head via Europarts installed if that makes a difference.
I've taken some close ups but cant get photos on.
JOSEMI
Post Sun Nov 06, 2005 9:38 pm
It looks like a 2.5 to me, the dizzy cap, the reservoir on the passenger's side, the way the water pipes are distributed...
Jose
tourer-dan
Post Sun Nov 06, 2005 9:40 pm
at the bottom of this little message, there's a tag that says 'PM' press it, then send me the last 7 digits of your chassis number, then I'll let you know what size engine was originally fitted to this car.
E30Mark
Do you have the receipt for the new head???
In your picture, it looks like your valve in the vacuum hose to the brake servo is busted...
PM for details
Post Sun Nov 06, 2005 9:44 pm
JOSEMI wrote:It looks like a 2.5 to me, the dizzy cap, the reservoir on the passenger's side, the way the water pipes are distributed...
Jose
He knows it's supposed to be a 325. We're trying to work out if someone has slipped a 2 litre in.
The fact that it's had a new head suggests it may be a 2.5, since these crack heads far more frequently than 2.0s.
The most likely reason for swapping in a 320, would be because of a cracked head on the 325.
DazzyA
Post Sun Nov 06, 2005 9:57 pm
Found receipt for 325i/525i M20 Ԛ£160 instead of Ԛ£706 BMW one, ouch.
Valve in the vacuum??? i've just had a look and am none the wiser. This is my first "Classic" and am a total beginner. I'm still waiting for my Haynes to come through.
DazzyA
Post Sun Nov 06, 2005 10:04 pm
Brian is the 320 ECU ok with the 325? or should I get a new one. Also what is the other unit behind the glove box?
Simon
DazzyA wrote:. I'm still waiting for my Haynes to come through.
When it comes, throw it straight in the bin :lol:
Bentley is the manual to get, you can buy it through the zone, from the front page.
DazzyA
Post Sun Nov 06, 2005 10:05 pm
thanks Simon I will, I need all the help I can get.
Simon
DazzyA wrote:Brian is the 320 ECU ok with the 325? or should I get a new one. Also what is the other unit behind the glove box?
It will run, but not how it should, you should get a 325i ECU in there as soon as really.
The other ECU above the glovebox is for the ABS system.
JOSEMI
Post Sun Nov 06, 2005 10:07 pm
hmmmmmm
Brian, if they swaped heads would the performance be affected then, say to the 2L parameters ?? - I assume it would but I am no expert.
Jose
Post Sun Nov 06, 2005 10:42 pm
JOSEMI wrote:hmmmmmm
Jose
2.0 litre heads and 2.5 litre heads have completely different combustion chambers, and are not interchangeable. Can't work out whether it would go bang the first time it turned over, or have an extremely low comp. ratio.
Regards the engine ECU. If it's the wrong one, it would run as Simon says, but the maps would be all wrong.
JOSEMI
Post Sun Nov 06, 2005 10:48 pm
I was going to say 'drive the car to see what performance gives' but now it would be out of the question in this scenario. Although if they converted a 2.5 to a 2.0 then it would be clear what engine they put in ? I mean as to see what engine is DazzyA got in his car.
Edited: about the compression, you're the expert. In my opinion it would be 'bang' or the engine leaking all over the place, but I guess that's an over simplified vision of what would happen.
Jose
DazzyA
Post Sun Nov 06, 2005 10:54 pm
I must admit she dosen't sound like a 2L she has a real deap growl but seems sluggish at low revs then the power just builds and builds. So I should get a 2.5L ECU then?
Pass me the spanner
E30Mark
Post Mon Nov 07, 2005 12:06 am
I believe you just need a 325i chip, the ECU's are the same... could be wrong!
PM for details
schmick325
Post Mon Nov 07, 2005 7:41 am
I guarantee that inlet manifold is a 325i. A 320i has small 'kinks' in those 6 silver runners while the 325i has them all smooth like the ones in the picture
DazzyA
Post Mon Nov 07, 2005 7:02 pm
Spoke to the previos owner and he has emailed a copy of an Invoice from BM spares of Harlow with a 325 M20 engine #22134234 so am happy it is a 2.5 L phew. So what about the ECU i have different views, are they the same or should i change. I was only after the chip to get rid of the flat spots and have a better idle.
Pass me the spanner
Simon
Post Mon Nov 07, 2005 7:39 pm
DazzyA wrote:Spoke to the previos owner and he has emailed a copy of an Invoice from BM spares of Harlow with a 325 M20 engine #22134234 so am happy it is a 2.5 L phew. So what about the ECU i have different views, are they the same or should i change. I was only after the chip to get rid of the flat spots and have a better idle.
Just get a 325i ECU last 3 digits 173, they are readily available...actually I have a spare here, Ԛ£40 posted.
DazzyA
Post Mon Nov 07, 2005 8:05 pm
How convienient, how about Ԛ£30, do you take paypal payments?
Pass me the spanner
Simon
Post Mon Nov 07, 2005 8:30 pm
DazzyA wrote:How convienient, how about Ԛ£30, do you take paypal payments?
PM sent.
DazzyA
Post Mon Nov 07, 2005 8:39 pm
one back to you Simon.
Pass me the spanner
DazzyA
Post Wed Nov 09, 2005 9:19 pm
Got a 173 ECU from Simon, good price, first class service top man, the car is now like a white knuckle ride and can't stop smiling :mad: thanks for all the help.
Pass me the spanner
Simon
Post Wed Nov 09, 2005 9:24 pm
DazzyA wrote:Got a 173 ECU from Simon, good price, first class service top man, the car is now like a white knuckle ride and can't stop smiling :mad: thanks for all the help.
Glad to help mate! 8)
