Diff
Thestig
Post Sun Nov 06, 2005 8:10 pm
hi there, just new to the forum, just bought a 1990 325i SE, any idea on what diff it has on it, cos heard some people say it got a lsd and some say it has a normal one,
cheers le stig :cool: :cool:
E30Mark
Post Sun Nov 06, 2005 8:18 pm
LSD was an option on the SE model.
PM for details
Thestig
Post Sun Nov 06, 2005 8:20 pm
cheers mate, is there anyway of knowin with out takin it to bits, cos sometimes it feels like its launchin off with both b ut then sometimes its doesnt, le stig :cool: :cool:
Andy335Touring
Post Sun Nov 06, 2005 8:22 pm
Find some where quiet to play and let rip in first gear........
Two black lines = LSD
One black line = open dif
or......
jack one wheel up, remove the hand brake and try to turn the wheel, if it's very hard to turn it's an LSD
or.....
Look for a metal tag under one of the bolts that hold the rear cover on the dif, if it's an LSD it will start with an S, the next three numbers are the dif ratio, like in this picture for an 3.64 ratio LSD dif
Thestig
Post Sun Nov 06, 2005 8:26 pm
cheers mate, will check it out moro! thanx again later le stig :cool: :cool:
Post Sun Nov 06, 2005 9:11 pm
E30Mark wrote:LSD was an option on the SE model.
Sport and M3 where the only models with LSD as standard, IIRC, but it was a fairly cheap option on any model. Surprising there aren't many more around.
OllieB
Post Sun Nov 06, 2005 9:15 pm
Jack up both wheels and spin one by hand, if the other wheel spins the same way then it is locking up. If it spins backwards it is an open diff. Standing starts are not conclusive as open diffed cars will often spin both wheels if the surfaces are the same. Try and do a donut.....
I'm too scared to drift properly......
