Pressuming low oil pressure is the cause...
Just had my car up on the ramp, took the sump down to change the oil pump & noticed the oil is grey with a metallic tinge.
Also the crankshaft has some play...
Looks like a bottom end rebuild or should I change the lump for a known good one.
Any advise would be appreciated....it is a m20 325i.
