Auto to Manual parts list
chu346
Post Sun Nov 06, 2005 4:18 pm
It looks like my auto box is leaking. So I might take this opportunity to fit convert to manual!
I would like to know what parts are needed and any other help or advice would be apperciated.
Parts I know I need:
5 speed transmission (Hopefully sports box)
Driveshaft for a 5 speed (is this really needed?)
brake and clutch pedal box
shift knob
all shifting mechanism
clutch fluid resivoir
clutch kit
shift boot
new transmission mounts
Anything else?
stevetigger
Post Sun Nov 06, 2005 4:42 pm
The wiring from the manual!
Post Sun Nov 06, 2005 4:54 pm
stevetigger wrote:The wiring from the manual!
No, the auto wiring is OK, apart from you need the small loom from the centre console down to the gearbox for the reverse light switch.
Removing the starter inhibit is just a matter of removing a small loom and a relay, and pushing two connectors together.
Some have said that the ECU gives too high an idle speed, IIRC, but I've never had any problem using the auto one.
You need the manual prop. to fill up the nasty gap you will otherwise have in the driveline.
Missing from your list is the flywheel and spigot bearing.
chu346
Post Sun Nov 06, 2005 5:03 pm
Ok then so:
Driveshaft for a 5 speed (needed)
shift knob
clutch kit
shift boot
And does the clutch fluid reservoir bracket need welding on?
Post Sun Nov 06, 2005 5:31 pm
chu346 wrote:Ok then so:
shift knob
clutch kit
shift boot
And the little reverse light loom as I mentioned above.
Yes, the bracket for the clutch resevoir is welded on in factory manuals, and I always have in the ones I've done, but it shouldn't be rocket science to fabricate a bolt on one.
chu346
Post Sun Nov 06, 2005 7:25 pm
Ok then:
shift knob
clutch kit
shift boot
reverse light loom
Cheers Mr Moooore :cheers:
If anyone has any of the above parts for sale please let me know.
Dan318-is
A miracle?
Post Sun Nov 06, 2005 7:50 pm
I have all of these bits in a 325 i am fragging the car is still running and driving and can be driven. The clutch is excellent and was replaced about 18 months ago.
mrLEE30
Post Mon Nov 07, 2005 7:56 am
diff is different too, ratios are not same, auto diff i think will give better acceleration but less top end,
you also need the interior trim surround i think?? and if i was you go for the Z3 (or similar) short shift, see tech articles on how to.
and please correct me if i am wrong but does the clutch not share the same fluid with the brake resevoir?? which means no clutch reservoir just you will need master and slave cylinders??
need to know cause about to start my conversion!!??
mrlee
Post Mon Nov 07, 2005 9:07 am
mrLEE30 wrote: and please correct me if i am wrong but does the clutch not share the same fluid with the brake resevoir?? which means no clutch reservoir just you will need master and slave cylinders??
mrlee
Does on yours, but not on ours.
We have the brake master one side of the car and the clutch master on the other.
