Just got The car so not sure of its quirks.
Car starts 100% but idles like its off a cylinder, and when driving it hesitates Very badly.
After driving for a while it gets better but not 100%, does not seem to pull like it should, but up around 5000 rpm it seems ok???
Tried unplugging MAF and Engine runs rougher, definately better with MAF plugged in.
There is a blow out in The exhaust.
Also on downshift it backfires, not sure of thats to do with The stainless system or The Engine conversion.
Any Help appreciated.
Also The 3 relays by The MAF in The black box, what is The white one, its a Siemans, part number 12.63-1729004. I discovered a previous owner had fitted a switch across 2 of The wires and hidden it behind The glovebox
Cheers.
