Power Steering question
cpfcluke
Post Mon Feb 13, 2012 3:11 pm
Hi
Thinking of upgrading to power steering in my F reg.
Its a 318i
Could anyone quickly run though what parts i'd need and the basics of fitting.
Luke
rix313
Post Mon Feb 13, 2012 6:39 pm
Linkage
Pump
Pipes
Rack
Reservoir
Getting the rack changed is the biggest faf. Once the rack bolts are undone you have to bend the 2 lower tabs down to get the rack out. In true Haynes style fitment is reverse of removal :mad: When the rack is going back in it's a bit of a balancing act with the linkage and getting it all lined up.
BenHar
Post Mon Feb 13, 2012 7:35 pm
rix313 wrote:Linkage
If you are some sort of cowboy.
Ben
redcar
Post Mon Feb 13, 2012 10:42 pm
I didn't have to bend my lower tabs when taking the rack out or when getting it in.
You can slide it in pretty easy from the side a‘€
