Window goes down fine.........
ivqii
Post Sat Nov 05, 2005 9:53 pm
.......But comes up slowly.
Motor or switch?
Any advice?
stevetigger
Post Sat Nov 05, 2005 10:50 pm
Motor
You can check the switch by swicthing it with the other swtch to see if it is the switch, try that first! I bet it aint the switch!
Post Sun Nov 06, 2005 12:13 am
OE motors don't usually give much trouble, but the (sometimes dealer fitted) retrofit ones do.
Try silicon grease sprayed into the glass guides before you get to involved.
doug325i
Post Sun Nov 06, 2005 5:36 pm
This seems to happen to the rears alot if left unused for a while.
lube em up and they should be ok.
ivqii
Post Sat Nov 12, 2005 1:27 pm
Brianmoore you are a gift from god :D
Many thanks
