Viscous fan replacement on M40 318i
stew72
Post Sun Feb 05, 2012 12:09 pm
I've recently had a specialist replace the cambelt, waterpump and themostat so now the temeprature gauge reads somewhere about right as before it barely moved as I believe the thermostat was stuck open.
Stuck in traffic last week I noticed the gauge moved from half way where it had been sitting to nearly 3/4's which caused a little concern. I've tried the newspaper test, at idle when cold it stopped the fan turning easily and when the temp gauge was showing half way it did the same. I assume that doing this at idle was correct?
If it was I assume I need a new viscous unit, so how easy is it to replace? I assume that its a left hand thread?
Where's the best place to get one, seen them on ebay at less than £30 delivered, are these any good?
And finally, should or could the specialist have spotted this or even caused the problem during the work they did?
Any thoughts appreciated.
Rancid
Post Sun Feb 05, 2012 12:12 pm
When mine went i repaced it with a new Sachs one, i was advised that they're the only ones to bother going with.
Yeah, it's left hand thread, not too difficult to do either, pretty sure there's a how-to written out somewhere i'll see if i can find it and post the link :)
Formerly known as Rancido64.
e30less at present, working on that one....
-> Xbox360 Halo freak, GT: a wild Rancid
Mobile Phone Technical Support:
Got a problem with your mobile phone?
PM me and I'll do my best to help :)
Post Sun Feb 05, 2012 12:24 pm
Just bought one from GSF - about £30 - Made by Borg-warner IIRC
GSF do two - the one I got was the more expensive one.
Billwill
Post Sun Feb 05, 2012 3:53 pm
It is a left-hand thread....put a large spanner or large shifter on it and give it a sharp knock in the right direction. Then unscrew it and lift it out clear of the fan shroud. :)
hongkongfuey
Mad-tango-geezer
Post Sun Feb 05, 2012 5:17 pm
Its 32 mm
with cars like mine,
