timing belt on m40 engine i have put it all i time removed the old belt and i used the lockng tools,
ok to me the side of the belt with the idler looks to be to slack when tension is on i have pix so if you can see what im talking about
tension is on in the pix
should i be able to push the belt that much ???
i bit the bullet and turned it my hand all was good and then i rememberd to set the tension once i had turned it by hand so put it all back it time and redone the tension
its all good and look right
