obc unit
fenn2160
Post Sun Jan 29, 2012 6:17 pm
can anyone advise me how to remove the obc unit in the dashboard? as the pixels in the screen are going.
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Jan 29, 2012 6:24 pm
Here we go. Just follow these instructions in reverse :D
http://www.e30zone.net/e30zonewiki/inde ... itting_OBC
Post Sun Jan 29, 2012 6:43 pm
Can be removed just by taking off the access panels above and to the right of the glovebox, and then using a (preferably magnetised) small cross head screwdriver of an appropriate length, although you will be working pretty much blind.
Reach in past the OBC and get the screwdriver to engage with the two screws on the far side, and undo them around three full turns, then completely remove the two screws on the near side, and the OBC can be pushed in on the LH side, then slid from the slotted mounts on the right.
