Guys
Our '89 320i Touring is on occasion difficult to start from cold, requiring the use of the throttle to get it going and then a strong smell of petrol for a couple of minutes once going. (This happens maybe once a week.)
Not sure if it's connected, but when the car does start normally from cold, the revs are hunting up and down quite dramatically until the car is driven when they then return to normal.
Any ideas on cause? All service parts recently replaced.
Many thanks.
320i difficult starting and cold revs up and down!
rover-2000
Kind regards
John
1989 320i Touring
1993 E34 525i SE Touring
1979 Porsche 924 Lux
1982 Porsche 924 Lux
1985 Porsche 944 Lux
John
1989 320i Touring
Air leak from the bellows joining the inlet to the AFM or faulty/dirty ICV.
Bellows from the stealers are about £15 ( or were last time I bought one a couple of years ago )
ICV can be removed and cleaned with carb cleaner.
Rtaylor2208
Agree with Rob, ICV is most likely the cause and a good clean should sort it out.
rover-2000
Thanks guys. Now please remember I'm a numpty with these cars-where do I find the ICV and what does it look like...?
Kind regards
John
1989 320i Touring
John
1989 320i Touring
Standing at the passenger side of the engine bay looking at the throttle body the ICV connects into the left side of the bellows and another hose into the throttle body. Both just pull out. There is an electrical connector too which needs to be unplugged.rover-2000 wrote:Thanks guys. Now please remember I'm a numpty with these cars-where do I find the ICV and what does it look like...?
It is held in place by a clamp underneath which needs a 10mm socket to undo the nut.
rover-2000
Cheers Rob !
Kind regards
John
1989 320i Touring
John
1989 320i Touring
