fitting a towbar
thesaint
Post Wed Jan 25, 2012 7:48 pm
hi
got a geniune towbar, but not the reinforcement plates that go in the boot. Does anyone have some pics or measurements of these plates so i now what i am making?
here is a pic of what i have
thanks
1986 325i - Gone. 1993 318i touring, m52 in the planning stages.
jonny323i
Post Wed Jan 25, 2012 7:52 pm
i think this is what your after
Touring for life
thesaint
Post Wed Jan 25, 2012 7:57 pm
i take it then that its number 3 that i need to make?
number 4 is just a spacer?
is number 2 part of the bumper bracket or do i need to make this as well?
thanks! Would rather have some idea what i need to do before i strip it down as it is my main car atm so cant really afford any downtime
jonny323i
Post Wed Jan 25, 2012 8:03 pm
iv got no idea mate hopefully when i get mine everything will come supplied but i had this picture and thought it would help you
Touring for life
eko
Old timer
Post Wed Jan 25, 2012 8:26 pm
Youll need parts 2 3 and 4 mate.
Can take a pic of the parts with mine tomorrow if you like?
thesaint
Post Wed Jan 25, 2012 8:40 pm
eko wrote:Youll need parts 2 3 and 4 mate.
That would be great if you could!
eko
Old timer
Post Wed Jan 25, 2012 8:44 pm
No problem,ill dig out he bits and get some pics on tomorrow night.
thesaint
Post Fri Jan 27, 2012 7:57 pm
did you mangage to get those pics eko? thanks
eko
Old timer
Post Fri Jan 27, 2012 10:28 pm
Sorry for the late reply mate,been manic :mad:
Not the best pics im afraid but hopefully itll give you an idea of what you need.
Couple more to follow as photobucket is playing up....
eko
Old timer
Post Fri Jan 27, 2012 10:33 pm
Sanchez
Post Fri Jan 27, 2012 10:43 pm
The big long bit part 2 slides into the chassis. The chassis already has bolt holes so you can measure them to get the length right.
You'll need to drill 2(each side) holes in the body for the extra bolts on the bracket.
Seen better here. The bumper mounts are replaced but only holes in shell for lower bolts.(does that make sense?)
thesaint
Post Sat Jan 28, 2012 1:08 am
thanks for the replies, the part 2 is that just box section? what size is that box section please? looks esasy enoughish to make up.
thnaks
eko
Old timer
Post Sat Jan 28, 2012 10:19 pm
Size of box section is 315mm x 30mm x 30mm
