The needle's never really been over half way in the year I've owned it until recently. Now whenever I stop in traffic, or even just at lights if it's for a while, it starts creeping up to the red till I can start moving again. After a couple minutes of cruising it's back to normal.
Leads me to believe it's the fan, but I'm also having intermittent problems with the heater, and now for the best part it's blowing cold even when overheating.
Any advice would be greatly appreciated as I have next to no knowledge of how my car works.
Thanks.
318is over heating.
kam-325i
water pump may be on its way out.
Jos
not being cheeky but is there any water in it?
What hoses are hot?
What hoses are hot?
'94 e36 tree climber
DHFiS
viscous fan failed?
kam-325i
The heater would still blow hot if the viscous had failed.DHFiS wrote:viscous fan failed?
bodger
check your coolant level, then go from there
